Will a 40 work on a 41 sprocket, but not the other way around? I need a 40, but mistakenly ordered a 41, and there is no way it works for me. The pitch is the same, but the pin dimensions are very different.
I know the 41 chain I ordered for the mini gote doesn't even come close. That's why I asked the question. Oh and I also have 3 or 4 feet of #40 chain, brand new, if anyone needs it. I sure don't.
Ha! THANKS Chad! Hope I didn't step on Tippy with that. I mic'd the old chain and found it to be a 40. but had the chain lore wrong in my mind. Backasswards!
Tippy or Mayhem, I believe I have 4 feet of the 40. I cant use it.
Don't quote me, but it believe a #40 is .287" thick and #41 is .230-.235". Somewhere I have a reference sheet. The #40 on the #41 sprocket helps with sprockets that have a slight wobble to them.
Sent from my Texas Instruments Speak and Spell...[emoji2]
It can use whatever... it's a simple matter to swap the sprockets. Yours needs whatever size sprocket you have installed. If yours is 3/8" between the teeth it is #35. :thumbsup:
