You can read about pipe threads, modify an inexpensive pipe tap by cutting off the first several taper threads, and tap the hole a bit bigger. Then cut the first several threads off the male NPT to fit well. NPT are tapered, move the poorly-fitting taper further up the taper diameter. Hope this is kind of clear. There must be a YouTube video about this for a log splitter engine or such.
