I have a clone with:
.265 intake cam
Chromo Pushrods
Billet Rod
Billet Flywheel
Header
Flat top piston
File fit rings
18 lb springs
fuel pump
mild porting
And I have lots of carbs:
Tilly 363's (a bunch)
Tilly 357a
Tilly 227a
Mikuni 22
CRF50 Carb (22 mm)
Gx390 Carb
Gx200 Carb
I have an adapter for all of the carbs to the Gx200 head.
What carb should I use, and why?
*SIDENOTE*
Anyone notice that most tillys fit onto the manifold that AGK sells for the 22mm mikuni and the Gx390? All you need to do is file an area for the pulse and it works just fine...
.265 intake cam
Chromo Pushrods
Billet Rod
Billet Flywheel
Header
Flat top piston
File fit rings
18 lb springs
fuel pump
mild porting
Tilly 357a
Tilly 227a
Mikuni 22
CRF50 Carb (22 mm)
Gx390 Carb
Gx200 Carb
*SIDENOTE*
