use??
  1. Z
    what brake systems can I use??
    I want to get a new brake and sprocket set up on my mini. Can somebody show me a link to all the brakes that are available for this rim Thanks it is a 6inch rims. Also what sprocket do I need that has a big enough hole for the brakes? thanks.
  2. C
    Premier Clutches- Which one to use??
    I am in the market for a new drum clutch. I don't want another MT, and I would like to hear your guys opinions on the Noram Premier series of clutches, and which one I should get. The engine is a 5hp flathead with billet rod and flywheel, mild porting, shaved eyebrows, and a straight pipe.
  3. C
    What carb to use??
    I have a clone with: .265 intake cam Chromo Pushrods Billet Rod Billet Flywheel Header Flat top piston File fit rings 18 lb springs fuel pump mild porting And I have lots of carbs: Tilly 363's (a bunch) Tilly 357a Tilly 227a Mikuni 22 CRF50 Carb (22 mm) Gx390 Carb Gx200 Carb I have an...
