I’m looking for std rings for my 130202 5hp. Is 299742 the correct part# rings for it. Bore Diameter measures between 2.5615 and 2.5625. It’s an aluminum bore so I need chrome rings
I've been lurking for a while and reading a lot of the Briggs posts so I figured I'd introduce myself and my project.
I have a 1972 or 73 Sperry Rand Tricub "trike" which I have owned for about 15 years. It was sort of a father/son project for me when I was 12 or 13 years old - rebuilt it to...
Hello,
I have an original 130202 5HP Briggs motor on a boonie bikeIm trying to get going. Well I was taking the tank and carb off to clean and in the process of removing a sticky gasket I broke the plastic siphon tube beneath the mixing screw. The tube appears to be cast into the carb. There...
looking to buy all the linkage and springs that connect the carb to the tank and governor. thanks this is for the briggs and stratton 130202 1325-01 on my 69 boonie bike, also looking for the ski. thanks
I was told my motor was a 5.5 briggs but the 130202 are often referred to as 5 hp. I purchased a rod and piston off a used 5 hp 130202 briggs.
If they did make a 5hp and a 5.5 hp 130202 briggs would the rod or the piston be different/ or both?
I'm attempting to get my very first motorcycle running again. I learned to ride this bike somewhere around 1984 and I don't think it's run in at least 15 yrs.
I've cleaned out the tank and gone through the carb. I just bought a brand new plug and found no spark. If I grab the wire and pull...
Numbers matching 73 minibike motor.. Guy I got it from removed the air filter and original plug with gld paint on it still.. :angry: But... She's still a real nice original.. :biggrin:
