I was running .028 size jet and noticed i had bad throttle reaponse. So I ins5alled a .032 jet....runs perfect but now carb leaks. It seems like its coming from the top of the bowl. I made sure I put rubber seal back in... I need help.
Upgrades: dyno cam. 18lbs springs. Header. Air filter(no...
I recently bought new replacement parts for my carburetor, and once i put everything together and plugged the guy back in it would start to leak oil. From what im pretty sure the source of the leak is coming from the little hole in the picture. Im currently taking it apart again to see if i...
whats up. had same problem on a clone (jf168) and a tecumseh 3.5 powersport. the carb is leaking fuel. on the clone i cleaned the carb and it stopped. on the tecumseh it leaks from the bottom. i got it to stop briefly and it started comin from the air filter. i then broke the float bowl...
