Hey guys, I recently rebuilt my Hisun 196cc motor and when I run the engine it idles roughly. Here's some specs
18 LB valve springs
PVL Aluminum flywheel with 31 degrees BTDC
Billet con rod
governor removal
BSP-2 cam
Everything else stock
The engine seems to run fine at higher RPM but at idle...
well im doing a sort of restoration (makeing it look ok and run decent) and i know they used an older tecumseh flathead 3-4 horse but id like to know if a gx_200 honda clone engine would fit on it thanks
