okay, installed arc rod, flywheel,18 lb. valve springs and my hf 6.5 developed a knock. pulled the side coverand found cam and crank gears had rubbed the side case a little. upon further inspection, found side to side play in the rod-crank. so...obviously the bearing went away. would i be better...
