So I picked this up it was on a bird mini bike. Adds say it came with a 3.5hp but there was a model with the 3hp. Head gasket is extremely smaller then the hs40 head gasket I compared it to. But it’s a slightly newer engine off an old Aries snow blower. Shaft is smaller diameter on the lil older Tecumseh to. Dunno if that matters. Nor size is 2-1/2” if anyone knows what piston rings parts number would be. And can I upgrade the valve springs and cam. Maybe off a different hp Tecumseh. Also the gov arm going in to the block seems sloppy is there a seal that firs bad?
