I need to remove the pulley from the PTO and drill and tap the PTO for clutch retention. I have been reading that the weak point of these old Clintons was the connecting rod. This is an A400. They made an A490 which had a ball bearing on the PTO side, but still had a rod that was fine as long as the governor worked. The last version was the 500, which had a much stronger rod in it. That rod was used by the kart racers, and I have not had any luck finding finding one, or most of the hard parts for this engine. So, I posted a want ad.
https://oldminibikes.com/forum/index.php?threads/hunting-for-a-panther.179493/
I bought two old Clintons. The generator engine is a 500, with the stronger rod. My plan is to disassemble this A400, put the 500 piston and rod into it with new rings and gaskets, ignore the governor and use it on this mini bike. Then use the A400 rod in the 500 with the governor on the generator.
If that swap is a problem, I do not mind using the governor, it just has a backward, odd setup where the cable has to PUSH the lever, rather than PULL it.
