OK.
So this site has great mandates (and info) on NOT removing the governors to exceed the factory governed speed of 3600rpm (spec 3600 +/- 150 rpm per manual).
The first thing a kid usually hears when even mentioning wanting to own a mini-bike is that it is dangerous and to "forget about it".
So, nanny lectures aside ... who really knows the safe un-governed (or partially governed) RPM's that these HF 6.5 clones will take?
Who actually MEASURES?
I have seen failure analysis done on reciprocating aircraft engines, I know the concepts of piston speed and piston acceleration with these 54mm bore engines (and that stress loads on parts roughly increase 4 fold per each 1000 rpm increase), I have seen the anecdotal pictures of trashed (grenade engines) BUT what is the safe limit that you all think these engines can handle in RPM's STOCK (no parts replacements no load) from measured experience?
The reason I revive this issue is that #1) I don't see many tachometers being used on the engines that are exhibited as "grenades".
#2) I see the "tradition" of making the flywheel and the connecting rod w/extended oil slinger, more robust with aftermarket parts as an anecdotal precaution.#3) I see broken pieces but damn few measuring tools.
SO has anybody actually ran these motors at over 3600 spec RPMS and quantified the results by measurement? Somebody has to have actual factual quantified experience (racers?, re-builders?, shop equipment sales?)
Summation: max 3750 RPM's OK by factory spec with proper oil and proper oil level @ recommended operating temps.
What's the first KNOWN weak link in the power-train components when over-revving >3750RPMs?
(oh...PS... I did use the Search feature, lots of stories, few actual/factual numbers or measurements)
