made up clutch cover mounts.Im not sure what the original look like made a couple of spacer and bent some flat bar .checked valve lash spot on ,head off crosshatch on cyl looks good,removed govenor found pieces in sump.plugged hole with 1/4 bolt I found that it will cut its own thead when installing.painted this morning will give it a week to harden and then put the tins on
