224 help!!
#48
So thought I would post some updates. On the motor that didn't have the bad cam I added the new dovan coil, shimmed the valves to .850, and installed 2 vents with pcv off the valve cover. I also talked to ec carbs and he suggested a different carb. I picked up a nibbi 26 flat slide. Today I got it running and did some testing. Still only got 5650 for rpm. I am jetted at 135 main and 38 pilot (kehin jets). This pic is of a new plug after some blasts. Looks a little lean to me. Went to 140 main and was worse. So still need to figure it out more. Also have a 7 inch driven to try when I get the carb figured out.
