I am looking to upgrade my cam on my clone. It has a .265" right now from AGK. My carb is a 22mm mikuni and I'm running 26lb springs. These are my options:
.275":This is great cam for classes with a .275" max lift rule. This cam has .275" lift and 238.5* duration @ .050" lift. Cam pulls hard all the way through the power band. Excellent choice when using stock size valves and a good carburetor.
.276":Custom Ground .276" Lift Cam with 246* duration @ .050" lift.
This is our favorite cam with amazing power throughout the power band. Capable of 8000+ rpm.
This precision ground cam is great for increased horsepower and torque. Hard face welding is used on the lobes to reduce wear. Cam performs great in all engine applicatioins.
Instructions included.
What is the major difference in performance between these 2 cams? The .276" is 50 bucks more. Will my carb be fine with either one of these? Thanks in advance!
