Guys take a look at this photo. I've got a couple differnt linkages called out. Just need to clarify that I'm going about this the right way.
The green line shows the solid wire link between the throttle and gov.
The blue line will be the throttle control input - twist throttle
The red is (I believe supposed to be a spring) that makes the connection between the throttle input and the gov.
QUESTIONS
1. Are the above assumptions correct?
2. Green Line - What is the hoop in the wire rod for?
3. Where do I get that spring and can I make one out of my local hardware store's hittman supply stock?
QUESTIONS
