Hello. So i am having a bit of an issue with my titan clone motor. It has a mikuni & governor removed. I was riding around on it , & was accelerating from a stop when my tire blew out and i felt the bike immediately skid to a stop & the motor died. I wheeled it home, thinking nothing of it & put a new tire and tube on. Then went to start it and it would barely fire, And would back fire out the carb and exhaust. I reset valve lash just to be sure. I know it is not the carb since i tried the carb on my other clone and it worked fine, also cleaned the carb anyways to be sure. its not an air leak. Oil level fine. Getting spark. Not sure what else it could be so i am wondering if it is possible that the flywheel key got sheared when the tire blew out? I did a visual exam of the flywheel key without taking the flywheel off, but it didnt look sheared, but i am not sure if one would be able to tell unless you took it off.
