Installed the cam, lined the dots up on the cam and crank. (Although I don’t recall if I made sure it was TDC, if it was not can the cam be installed 180 out?)
Set the valve lash at what I believe was TDC. My feeler gauge only went down to .004, so I used the side wall of a PBR can. (I am picking up a better feeler gauge tonight to recheck the lash.)
Although a good feeler gauge set is indispensible for the toolbox, I think 0.004-0.006" intake and 0.006-0.008" exhaust clearance would be fine.
It didn’t want to fire without giving it a little gas. With choke on I got it to fire, but it didn’t want to run with the choke off.
Suspected too small of a pilot jet. I swapped jets - replaced the stock #15 pilot jet with a #17.5 and swapped out the main jet that was a #95 but I drilled it out a bit (have to go back and check how much tonight) to a #130 (which may be a bit much, might put a #125 in it, I have one in stock).
I found another screw on the side of my fakuni, turned it 1/8 of a turn counter clock wise and the idle smoothed out to just around 1600 rpm. Does anyone know what that screw on the side is?
And I noticed the occasional back fire on sudden off throttle…
But I have a bigger problem. This thing is an SOB to start; it still wants someone to work the throttle a bit while another person pulls. My arm sore today from pulling last night (no kick back though) lol. I’m wondering if its timing related, or if the higher compression head created an octane sensitivity issue 65shelby clone mentioned. (I’m not sure if the black mamba jr. would be considered a mild or lump cam.) I’ve only run high end pump gas in this motor, no race fuel yet.
One feature that digital EFI/ignition controllers will spoil you with is the ability to set really conservative advance numbers for cranking and starting. It can be pulled back to 10° BTDC during cranking, or even less, to help get high compression engines spinning. I am not a fan of locked-out timing for engines that have a dynamic load range. Once a utility engine is taken off of the generator or pump, that's what happens. I'm really thinking about injecting the GX340 I have...
