My motovox with a built predator and a mongrel clutch with the stock 75t sprocket has been doing great so I changed to a 65t for more top speed. I put the sprocket adapter on with a two piece 65t sprocket on it. I have the numbers facing out and the way it should be mounted but the chain is making an awful popping sound and making the chain climb off. I've only tried it with the rear wheel off the ground. It looks like the chain is lined up straight. I have the engine adapter to adjust if needed. Any help will be much appreciated. I was wanting to run it at the dragstrip tomorrow. Thanks
