I have seen in the past where its claimed that a 30/31º on the intake valve will allow a more little fuel and air to enter the combustion chamber for a power gain and supposedly no ill effects, anyone make the change on a Tecumseh? Currently thinking if giving it a go on an HS. I gave re cutting the angle to 30º on a standard 32644 intake valve a try with my refacers and got it done. That job would be better suited I am sure on a dedicated refacing/grinding machine as it fought a little with a Gizmatic and produced some chatter marks at first. So I did the main reshape cut then put it on my single blade recutter, smoothed it out, and then back on the Gizmatic and it was fine. I would imagine some that have converted to Briggs valves may have done this before?
I have not cut any seats yet in any blocks, Most likely do it to an HS50 that I have already bored .010 oversize and its just sitting around. If you have done it, or maybe seen it done on a small frame Tec with some feedback on how it turned out, I would be interested in hearing or reading about it as I would be curious on how your seats turned out (I do have a 15º cutter in my toolbox so I can make both upper and lower narrowing/adjusting cuts in this seat angle )
Before
after
Before
after
