Predator 212 non hemi. Has started becoming a bit of a pain to start. Before you barely had to pull on the start cord and have the throttle at idle to start. Now I have to hold the throttle about half open, and really yank on the cord to get it to fire with the choke on. Which then has the bike want to launch at the T/C tries to engage.
You have to keep it running by blipping the throttle choke off, till it warms up, then it will idle, but the idle speed screw is almost fully in. Anything less and it just dies. Once warmed up she runs normally, except for the higher then normal idle.
This is a stock cam, and yes I have checked the valve adjustment to make sure the exhaust wasn't too tight.
In making sure it wasn't a fuel problem, I dribbled a little gas in the carb, left the throttle at idle and choke on. Pulled the cord normally several times, and no start. Opened up the throttle half way, and again yanged like heck on the cord and she fired up.
Something I realized is the start cord pulls really easy, not once has it yanked back on me, like it would if I would try pulling the cord when not up on the compression stroke. I'm beginning to wonder if the compression release is sticking on, which is making it so you have to spin the engine over really faster than normal to get it to fire.
Before I tear off the side cover to check I figured I'd post this to see if anyone might have a different idea of the problem,or conformation of what I'm thinking is probably what it is.
Add on, has the 140 e tube, 37 main, slightly larger idle jet, billet rod /flywheel, pod filter, header,22 pound springs, ported/polished, governor delete, oil sensor delete.
All were in place from day one, long before this started.
