Found pieces I needed but now I'm not sure how to assemble connect together to make the governor operational a diagram would be great! Thanks
heres how Rupp did/suggested how. this is from the 1968 cub k1/k2 instructions (the kit version bikes) For whatever reason they packaged and sold the throttle arm and return spring themselves for some of the bikes, not sure if that was because Tecumseh was not specifically offering Recreational engines at that point or if Rupp felt they had a better return spring setup :shrug:
(It is a full size scan, you will have to go through photobucket to view it that way though.)
The arm has to point up and youw will need a linkage to the carb, this photo from a bike did years ago kinda shows that pretty decent:
And you do need to refer to the tec manual to know how to adjust correctly for the governor to work correctly
If you dont use the Rupp version of the return spring setup you will also need to get the proper Tecumseh torsion spring for the throttle arm.
