B bryce05 Member Mar 7, 2017 #1 Mar 7, 2017 #1 What are the benefits of a diaphragm carb? Are the better than a conventional Tecumseh carb. Just wondering
bikebudy Banned - Must pay $500 Mar 7, 2017 #2 Mar 7, 2017 #2 I don't have a lot to do with the diaphragm carb but, the only advantage is it can work on any angle. After working with my first diaphragm carb, give me a float carb any day when it comes to TEC engines. Just my opinion.
Sprocket86 Active Member Mar 7, 2017 #3 Mar 7, 2017 #3 Diaphragm carbs also have the ability to draw their own fuel from a source, providing it's equipped with a crankcase pulse fuel pump chamber. They also might operate better then a float carb in really rough bounce around type conditions.
creia Mar 7, 2017 #4 Mar 7, 2017 #4 bryce05 said: What are the benefits of a diaphragm carb? Are the better than a conventional Tecumseh carb. Just wondering Click to expand... What size engine would you be using it on? 4 Hp (HS40) is about the limit for those. We have very good results with them. Michael
Sprocket86 Active Member Mar 8, 2017 #5 Mar 8, 2017 #5 All of the Tec diaphragm carbs that I've come across have a small venturi and some even don't have an idle circuit built in to them. One of these carbs would be good for a factory angle engine mount mini bike that would require the ultra hard to find HS40/HS50 slant intake manifold.
B bryce05 Member Mar 10, 2017 #6 Mar 10, 2017 #6 Good info, I was just curious since I seen a couple for sale on eBay
