any autoparts store, bearing number 201 or 202ss brand national bearing, you can cross reference, them for other brands
AH I knew this would come up.
What is the difference between a 6201 and a 201????
I am a bit rusty now but off the top of my head I believe the 201 is what was called a Maxi Ball bearing. The didn't have a cage so there was room for an extra ball. These were a low speed bearing designed for heavier loads ( the number 30% higher come to mind but... )
They look the same untill you take them apart and I guess they would interchange in this aplication but its been a few years. Safest thing is put in what you took out, but sometimes the bearing dealers can make sugestions and offer different bearing for special aplications.
As I recall the 200 and 300 bearings were what we called the bearing of last resort for low speed High radial loads that were killing 6200 and 6300 series bearings.
As a further note there are also special clearence bearings. Hot running high speed bearings usualy have a C3 suffex. This means there is little more room inside for expansion. You can also use a 6201 c3 on your mini if you like you will never notice the difference. There was a time when I had " golden hands "
I could feel that C3 clearence and distinguish between it and a bearing to shaft or housing fits that were worn. I can't do that now though lol.
Its important to know that bearings warm up and cool down in use and they generaly move a little in the housing where they are mounted ( they slowly spin in the direction of rotation ). They must move for proper even wear and they must have the correct clearence to the shafts and housing. If not they will wear out faster than normal ( especaly if too tight or the out of round ).
Lock tight is not a fix for a fit issue unless your parts are scrap and your just trying to buy some time.
Todays bearings ( if you buy a good brand ) should last longer than any other part of your bike. The alloys, heat treating and griding are so good and consistent that all they realy need to last is the proper lubrication, to be kept clean and not be damaged from shock or hitting ( called brinelling damage little dents in the balls or races from eg hammer blows Thats why cars are strapped a little loose on trains to prevent the wheel bearings from being dent as the truck rolls down the rails just a bit of front back movent is enough to let them roll rather than hit in reaction to the joints in the rail ).
