Lol yea it has electronic ignition. Definitely changed or something at some point. Just make sure the coil gap is right (thickness of a business card should pass between the flywheel magnet and each leg of the coil.
What you DONT have is a charging system which would be wires from under your flywheel. That single wire on the coil is your ground/kill wire. Touch it to metal and motor shuts off.
