Not much for these small engines. Make sure they are full of oil and run them. And if possible, run them under load. The last mini bike engine that I "broke in" was the Hisun engine on a Coleman. It was initially started without a clutch attached and rev tested to check throttle response and idle speed. Then the bike was ridden, and ridden hard.
For my work clones they were started, idled a few seconds, then placed at full throttle to blow snow or leaves. I'm sure they broke in a few minutes after they hit normal operating temp.
Generator with a Ducar 208cc. Started it, and apply loads to it for 20 minutes then changed the oil.
Small block Ford 289. Started it, ran it for 20 minutes at 2K RPM's. Changed the oil then ran it hard.
Question.... If you buy a brand new lawnmower, do you do a break procedure, or do you start it and cut the grass? I would start it up and cut the grass. I think it just depends on what you are braking in to how careful you want to be.:smile:
