ALL items are NEW unless noted otherwise. ONLY USED ITEM IS LUNATI .563.
(2) blockzilla1 block kits,bare block,head,head gskt,sidecover,33 mikuni carb,breather plate,stainless valves,springs,seats,guides,lifters,+.140 chrome pistons,coil brackets and 3 step header.(will include sleeve if wanted but no piston) these are BARE blocks-require all machine work.$400.00 each
(1) lunati +.400 $150.00 (1) used lunati +.563 mag gd $100.00 (10) bz semi finished heads(need transfer port blending)$30.00 each (3)bz sidecovers $50.00 each (2) 3 small motor 3 step pipes $15.00 PISTONS (1)cv 3.100 piston w rings/pin $ 60.00 (1)wiseco +.174 unchromed piston w rings/pin $50.00 (1) wiseco +.100 chrome piston w rings/pin$50.00 (1) wiseco +.140 chromed w rings/pin $50.00 VENOLIA pistons w NO rings- $40.00 each (4) 3.447 (1) w coated skirt- (1) 3.497 (3) 3.220 (2) 3.070 (2) 3.025 (1) 3.065 (3) 2.980 (1) 2.755 - WISECO RINGS $15.00 each or buy all at a big discount (2) xc2717 (1) xc 2736 (2) 2776lg (4)xg3032 (3) xc2992lg (1) xc3465 (1)xc3307h (1)xc3307lg (1)xc3445 (1)xc3465 (1)xc3514h (2) 3 degree coil brackets $15.00 each (1) time machine $25.00 (1) arc breather $75.00.misc. guides cam/crank gears.I have some used rods and pistons lemme kno, wont bother listing (15) gd used billet cams. 559-270-5208
