Gas Leak
I recently purchased a used Baja DR49 minibike. As soon as I turn on the fuel valve, fuel comes out the air intake of the carberator. I installed a new carb, but it still leaks. Any idea how to fix it?
Sounds like a stuck float/needle valve problem, but not for 2 carbs??
If the tank is full of crud then it will do it with as many carbs as you can put on it.
I would start with pulling the tank off and cleaning it thoroughly. Then clean the carb and try it again.
Doug
