Hello jspec, GC160 has butterfly carb, so look for location of throttle shaft and the idle adjustment will be close by. On mine, if you look at the engine on the pull starter side you will see the adjustment screw with the coil spring at the top of the carb. It's not easy to get to, I use a long phillips screw driver to adjust it. Hope this helps. :shrug:
