Black mamba cam fits new predator and gx200 50$
Billet rod +10 with flattop piston 100$
22mm mikuni carb kit 110$ jetted perfect
1.1 ratio reinforced rockers 20$
14cc head milled 0.65 75$
Pushrods 0.65 shorter 30$
Also have stock parts
Rod
Cam
Crank
Carb
Piston
Pick up only Michigan
Possible trades
Thanks for those links Phil,i actually found some info and stuff i needed. :thumbsup:
so,if you can nab a crank thats Brand New for 25-40 bucks,whats a used crank worth...?
for that matter,any of these used parts...?
Listen carefuly.....
Dangerous parts like flywheels have to be watched very closely.
A few years back it was common to use the GXV160 flywheel.
This was a good cast part but not billet ( I still have one in service ).
Used ones were sometimes a crap shoot because you could not be sure if it was abusd and beaten with a puller or over torqued with an impact.
I never heard of one failing but I have seen some develop cracks from frequent removal and bad practices...
Taper damage can happen too any aluminum flywheel.
Advantage PLV with the steel hub center
A used crank however is not a bad thing provided its not been damaged or has excessive wear.
I personaly would expect to pay less for a used one than new simply because I can;t inspect it first.
