i bought an air compressor with a h35 engine. i am using the engine for a mini bike. problem is that the engine will not start at idle. if i turn idle screw in several turns to increase engine speed it will start and run, then i can turn screw back out and it will idle ok and rev ok. i dont want to start a mini bike at full or half throttle. is this carb maybe designed to start at full throttle? should i change carb or is there something else i can do.
