I've had this engine for many years, and I used to race it nearly 2 decades ago on karts. I finally dug up all the stuff to freshen it up. It's pretty much a stock Motorsports engine, but the head is milled .040" and I'm running a float carb this time around instead of the Tilly. I decided to paint it Silver, and I'm going to put the old school 5HP crossflags decal on it.
Std bore H50
Motorsports heat treated crank
Motorsports billet rod and piston
Motorsports cam
Motorsports springs retainers
Stainless Valves
Motorsports springs
Motorsports hot coil
H60 float carb
Custom delrin velocity stack
Single stage header
I want to find an old mini bike suited for a big block (and an, um, advanced size older guy) to put this on.
j
The NOS Motorsports cam I had 1 1/4 lobes engraved on the backside of the cam. The base circle is 1" so it is s .250" lift cam (I'm not sure what stock H50's were) and it has a little more duration than stock cams. These cams always made great torque on karts, so I think it would be great for a mini bike.
Std bore H50
Motorsports cam
Stainless Valves
Motorsports springs
H60 float carb
Single stage header
j
