A quick look at what you did ( considerably more radical than I need ) tells me I should be smoothing the sharp corners under the valve seats ( radius ) and givng the top of the runner a little contour around the valve guides. I don't want to increase port size just smooth things out a bit.
JD knows what I am after he gave me some pointers but I still would like to see what has been done.
I'm looking to make about 10 hp from the GX200 clone at 5000 rpm with as much low end torque as possible.
I chose a Tilly HL 166 carb ( just a little larger than stock ) and my own port match intake that swings the carb up and out of harms way
YouTube - More of the Baja
test video of the carb and intake on a GX 160 clone ).
The undercut stainless valves look interesting....
The NR 252 -0211 cam seems to fit the bill ( according to NR )...
Arc rod, header, flat top piston and .040 millled clone head.
I don't want to shift too much of the power and torque up the rpm range and I don't want or need the thing reving up beyond about 6000 rpm.
Basicly I just want to make the motor perform better and have some stronger internals. I'm not racing I just want a bit more power to go with a TAV upgrade.
This engine ran like crap but I know why. Made from too many different bits and pieces. Next one should be significantly better
