well now i need a cam for my baja heat i guess you really shouldent run 26lb springs with the stock cam! lol the intake lobe is almost gone.
so here is the motors specs.
hf clone
ported and milled head .060
cm pushrods
arc .020 longer rod
gov gone
mikuni 22mm
stud kit
arc flywheel
8deg key
file fit rings on stock dished piston
1.3 rockers
I would like a cam that makes good torque and still rev to about 7,000rpm hell i want it to have good yank out the hole and then haul the mail all the way to 7grand it dosent have to sound radical i just want it to work well :thumbsup: i have an idea what i want to run.
this is it but will it work for my application.
Camshaft 274-MARINE, Special grind for Marine and Winch Boarding applications. Extreme torque. Designed for 3500 to 7500 RPM, 11 to 1 or Lower compression ratio required, 26 lb Springs required NRC-274-9810
hf clone
cm pushrods
arc .020 longer rod
gov gone
mikuni 22mm
stud kit
arc flywheel
8deg key
1.3 rockers
