What size drill bit should I use to drill out the idle jet on a baja 2.8hp? also what size drill bit should I use to drill out the main jet? (I have a header and a custom air intake on the engine). :grind:
Get the largest hammer you can find.
Smash the engine into small manageble bite sized bits.
Removed small bits and install new engine from HF.
Do this next month and you can buy a Preditor 7HP......
Oh bugger Clayton you live here in Saskatchewan......
Go to Princess Auto and complain wildly that you need a powerfist 7HP engine for you presure washer to 3 inch trash pump.
DO NOT take no for an answere........
Trying like a bugger to get that to work here in Ontario so far no good.
Next great leap forward in mini bikes powered by clones is the 212cc Loncin.
Wait untill you see the quality of the casting and the bore just screams 72mm Wiseco flat top with a ARC long rod.
Net result will be a killer 11.8:1 compression clone with an 18 cc head.
Finaly we are getting close to something that will clean its teeth with a World Formula brigs
