The tach instructions look to be for a two cylinder with a coil that has a hot and negative lead. If you have twin cylinder engine with a external coil, the tach leads (green wire) goes to the negative side of the coil and the positive lead on the coil goes to the ignition switch. If you have light switch, the light lead of the tach would go to the light switch and ground for the tach.
