No need to call me, just send the clutch. The drum and sprocket you have right now is useless on the McCulloch 49 because it has way to many teeth. It would like trying to start in fourth gear, yes you can do it a few times but then you burn up the clutch. I would put a 66 tooth to a 72 tooth on the rear sprocket, the more teeth the easier it is to get going. Try and stay locked up as long as you can. stop and go driving is very hard on any clutch and what ever you do don't ever drive a clutch vehicle in a parade. Parades are for torque converters, a clutch will not last the first block, you will anneal the spring and then you have direct drive where you have to stand on the brake all the time. Don't forget to measure the crankshaft and verify it is 2" long and the drilled and tapped hole is 3/8-24" . And also tell me if you plan on inboard mounting (sprocket next to crankcase) or outboard mount (sprocket by the bolt and washer). What difference does it make? So I send you the correct key length.
This site is for learning and it helps me with my spelling.
