First word that comes to mind is WOW!
Tips to others,
1. Dial down your throttle/idle adjustment before starting it the first time. As a precaution I had the front wheel against a wall, just in case. Glad I did, as I started burning rubber once I turned the choke off.
2. This is not a kids bike for beginners. I've ridden big bikes for 20 years, 400-1000CC, but this was a bit frightening as the acceleration was much more than I expected. Glad I left the other DB 30 in stock configuration for the boys.
3. Wear a helmet.
A few questions arose after this test ride.
Is there another way to take the engine speed down a little lower, like adjusting the air mixture, or something else I'm not aware of? I already dialed down the idle, and I'll make sure I adjust the throttle linkage tomorrow so that the gas goes all the way off. The issue was that the clutch was partially engaging at idle. Brand new Max-torque.
Will this get better after time as the clutch wears a bit, meaning I should just deal with it for now and let it break in?
Would dropping to a smaller rear spocket help solve this a bit? I realize I'd get higher top speed, but it would also make the engine/clutch work harder to spin the wheel initially, possibly eliminating this issue.
I can't ever remember doing a burn-out on a mini-bike before, with my 650's and 1,000's yes, but that was totally unexpected.
Thanks in advance.
Tips to others,
3. Wear a helmet.
Thanks in advance.
