Well Charles, u said it, he did gain in both area's because of testing and tuning to get the right combo, not everybody can calculate it up the first time and get everything perfect like u do. So tell me, without dyno tuning ur motors, how do you figure out the "perfect" RPM range and where the max TQ is when u dont dyno? I do know this, we have built two identical motors, down to head flow characteristics, and exact mapping on the fuel injection, etc, and both motors make different HP and TQ in different RPM's, Tell me how u can calculate this one, because on paper, they should both be the same right. WRONG, because no two motors are the same and this goes back to "testing and tuning" and that is what my bro did because he isn't perfect at calculating what should be or could be, because things that appear the same aren't always the same.
Dont get me wrong, cuz I understand ur point, but there are always variables that make all the difference in the world, when it comes to drag racing, because it all boils down to whatever comes up on the board at the end of the track, and we all know that in drag racing, a vehicle that goes 9.90's all day long can break out due to traction or clutch adjustments, etc., so in my bro's case this time the stall made that difference, and that is what I think he is trying to say. Nothing more, nothing less, he gained because he found the stall was the incorrect variable in his combo. Now dont keep hatin on him cuz he was able to find a way to go faster and gain RPM without asking you what the problem was.
I also understand that you have been building for 15 yrs. plus, but as soon as u can explain my example of two identical motors making different power then u will be the guru that all the engine builders in the world will come to because as of now there is no way to calculate why one motor makes more power than the other.
