Keep looking around those 3 numbers. They did sometimes stamp the year as two digits but it may have only been in like '70 or '71. Several of mine have it and I've seen others as well. I think it's usually above the digits you already stated.
Hello,
Contact Allied Leisure Group. They are the original founders of Lil Indian. Ray Michrina and family. They can tell you year and probably have most parts available for it if needed. Located in Michigan. Look online. Good luck. Greg
There are two things you can look at that I can think of. The bolt holes in the triple trees, if they are loose on the bolt then you'll have a difficult time correcting that now. If the bushings are old and worn at all, then they should be replaced. You definitely need close fits on those parts. My survivor has some play in it.
