Take out all of the bolts. Remove anything from the PTO (crankshaft).
Use a plastic hammer or a small board and a hammer to tap on the "ears" that hang out where the oil fill is on each side. There is a small metal dowel on each side. They look like bolt holes, but you did not have a bolt in them. Those are where it gets stuck. I hope that made sense.
Once it cracks loose, use a screwdriver to pry between the case and the side cover, carefully working your way around .
