Getting torque from a torquer cam the CL1
So if there ever was a torquer cam the CL would be it in the dyno line.
It,s a dual pattern which personally i have no use for, but im thinkin the folks at dyno figgered this cam could work with a stock muffler.
Your not pulling till after 4 k is a problem, your runnin dual pattern with a pipe on a motor with a better exhaust than intake arrangement, i can't think of a better case for a bit of over scavaneing.
Yyou need to get your intake working better so put a 1.3:1 rocker on there youll have to mod or replace the guide plate to work with it. You may need a little baffle in the pipe.
What else, oh ya jetting, pieolet mite not be giving you enough down low.
