Modding a Honda clone Engine??
#42
That bigger intake valve will love that bigger carb. But buying and having valve work isn't cheap. That whole process is worth more then the clone motor itself.
I have found a cheaper and better way about making more power. But of course it's all top secret.
Cheaper way is to buy HP right out of the box. The 11HP Clone is about$264.00 at Harbor Freight. Till I add up what I spent on my 6.5 to reach 11-12 hp, it's damn near twice the amount of the 11HP Clone. The only difference is that my 6.5 is light and has a lighter rotating mass, so it will hit the revs quicker than the 11HP.
#44
I agree with you on the 11HP not fitting most manufactered mini frames.
I guess the way I look at it is if you're restoring a mini, you stick with the engine it originally came with.
If you're looking to mod a bike, stretching the frame is relatively cheap in comparison to the cost involved in modding a 6.5.
#45
pz 22 carb??
The PZ22 slide carb your talking about is used on the Animal. That's the one I sell for $60, plus $10 for the intake brand new. It comes factory on the Animal, but works well on a lot of small motors. This is the Animal with the carb and intake.
Hi there
I am searching for a carb for my 6.5clone(stock now)but will be adding
arc rod-header-18# srings,I understand that the pz 22 is a great choice(that U sell)
is that a walbro carb??
can I use the pz22 with the tank on motor or do I have to go with the seperate fuel cell??
Thanx John,
#47
walbo carb
The Walbro PZ slider is a nice carb- around $100. I bought a new (NOS) 26mm Mikuni slider off ebay with the mounting flange cast in. I made a cable- thing works FANTASTIC on my 8hp Flathead Tecumseh. 2 years ago I bought a brand new 6.5 hp briggs Intek Pro OHV engine. Got a heck of a deal on it. I never ran it but turned around and sold it to a coworker who was building a barstool racer. It would fall on its face due to the "emissions" carb. He bought a new Walbro PZ slider carb and adapter (carb used on a Briggs Raptors)- $100 for carb, $10 for adapter. He claims the engine runs like a complete different engine. Very very fast. For what its worth I have a 6.5hp JiangDonger engine on my daughters TrailBronc. Runs real strong! I was pleased that the carb does not starve the motor as the Briggs Intek did AND a 5hp Honda GC residential engine I owned did as well.
Hi
I read your post,,I am trying to decide betwwen the minuki 22mm slide vs the walbro,it's for a kart just for play,from what I see the mikuni is about $40-50 and the walbro $100,
Im guessing that with the walbro you would be getting a better carb?
do u know which of these two carbs works on the animal??the cheaper or the $$
(my engine is the clone 6.5)
Thanx John
#48
22 mm carrb
I sale the 22mm carb, intake, rockers, and I even have a Zama/tillotson carb.
The 22mm carb works perfect on the 6.5hp version clone. That's what most of the kids run, because they get them from me. I get the rockers from a stock class cheater I can't name. But they make your motor sound a bit radical. They really help being that Hondas, and clones only have a .227" max cam lift. Which is way smaller then the briggs 6.5hp .255" lift.
I can tell you how to advance the timing, but if you don't have the correct tools you might screw it up. You can always buy a offset key that has already been cut. NR-Racing sells a lot of parts, but there extremely pricey.
You can get the tillotson carbs brand new from E.C. but they are a bit expensive. Usually for the carb, intake, and velocity stack it's around $160. Two models work great HL357A, and HL334wx. It's best to find one used, or new at a deal. The most expensive thing you will need is a billet rod for safety.
Hi mdb
do u know what the brand is on 22mm carbs that come on the animals,I am trying to figure out which off the 22mm are the best ( buy)for my 6.5 clone?
I am confused as to why if I look up a carb for the animal On say aps or ts racing the price is $100
when u can get them from mx or ebay agk for under $50, miniuki ect.are they one in the same thing just diff.prices? hope I explained this right?
thanx
Motra
The Animal comes stock with the Walbro. For the price I'd go with the Mikuni. They're very good carbs and easy to get jets for. AGK has the complete Mikuni tuning manual available for free on their site.
#50
mikuni 22mm
Oh that explains things,now I get it,thanx for you advice>>>>
#51
How to make 10HP plus from your Clone:
- Air filter adapter and Racing Filter($20-30)
- Free flowing header($30ish)
- Re-Jet Carb (90 or 92 Main Jet should be good)($2-3)
- Light port job to just round off the edges and smooth any burs(Free)
- Mill head 0.065" (Give you about 10:1 compression)(Free if you can find someone to do it)
- 1.2 Ratio Rocker Arms($20)
- 18pd. Springs($8)
- Advance timing 6-8 Degrees (Free)
- Cut every other plastic flywheel fin off with shears or a hacksaw (Free)
I gurantee this setup is more then enough power, Im running a clone with these mods on a Kart and damn is it fast. Higher compression and advanced timing gives you more low end pull and 1.2 Rocker arms with 18pd. springs will improve your top end noticeably. These mods shouldn't cost anymore then $100 at most but if your wallets are a little fatter a 22mm Mikuni with a manifold would top that setup off very nicely and would give improved power through-out the entire powerband. Most of these parts and how to articles can be found at Affordable Go Karts - Home page - AGK - http://www.affordablegokarts.com. Hope this helps everyones.
Nick
#52
a billet rod and flywheel would also be a good idea with the above set up. might as well toss a flat top piston it too if you have the rod out already.
#55
Yes I would recommend them also, you can never be too careful, especially with your motor right under the family jewels.:laugh:
#56
yep.
i really want to get one for mine now. my friend had catastrophic rod failure on his B&S flathead yesterday and it put a nice hole in the front of the block.
a billet rod and flywheel are the next things i'm buying. i'm thinking about maybe doing the whole motor since it'll be apart and it's tax return time.
#58
about the only thing i'm not sure about right now is what cam i'd want to go with.
i really want to get a different frame with a disc brake (thinking DB30) if i'm going to go for more power. the scrub brake on mine just isn't cutting it and that's only running 40mph.
i'm also a bit hesitant because i'll have to run 110 with the setup i want to do. the way this thing already sucks through gas, i'm not too excited about paying $12 a gallon.
all that this would cost me could also be spent much better elsewhere (still owe my parents $2500 and i'm moving soon and will have to pay double rent for a month then). i've already dumped enough money into this thing so i may just put it on the back burner for now and take care of other stuff. it's 100% for sure getting a billet rod soon, i want to do the flywheel too but don't want to drop another $100+ on that (it's also a safety issue, so i'll probably do it). if my hours didn't get cut at work it would be a different story.
#59
Well im not a cam guy so I cant help you there. Im going to be bolting my clone onto a DB30 but Im still thinking about replacing the brake on it with a hydraulic mountain bike brake or even a better mechanical mountain bike brake. I havent tested the stock brake system out yet but coming from a mountain bike backround I know the hydraulic systems are fairly cheap and easy to use/maintain so it just makes sense to me to spend the extra $50 bucks for probably twice the stopping power.
My setup as well requires a higher octane then pump gas, not really sure what im gonna do yet though. Im thinking about octane boosters but if that doesnt work out ill have to find a place that sells race gas.
Don't you just hate it when responsibilities get in the way of your toys!:001_tongue:
#60
a friend of mine has a hydraulic mtb setup that he'd probably let me have for either really cheap or free. i'm just not sure how to mount the rotor (know people that could figure it out though, but for more money). i'm also not real excited about this frame so i don't want to spend money setting up a disc like that and then wanting to go with something else.
if i could get a DB frame and run a hydraulic setup with the stock caliper mount i'd be happy. my friend's DB feels pretty damn steady at 45mph+. i'm waiting to hear back on a complete DB for cheapish on CL right now. if it's still available, i'm hoping he'll sell it without the motor.
i really wish i kept mine now that i let go a couple of months ago for $100.
