There was a box waiting on me last night when I woke up...
MBX11 hydraulic forks and axle bolt, MBX10 handle bars and risers.
The lower bracket on the forks can be moved up or down to fit the steering head.
The handle bars sit a little different than the stock DB30. I had to play with the adjustment for a few times to get them where I was comfortable.
Also, I had to file down the faces of the handle bar riser clamp pieces. They didn't grip the handle bars tight enough.
Stock DB30 forks.
Motovox forks.
Surprisingly, I did not need a washer as a spacer for the front axle spacers. My stock DB30 spacers fit just fine.
I will work on a mount for the stock DB30 front fender at some point.
I went for a short test ride before I figured out the riser clamps didn't grip the handle bars tight enough. Man, what a difference! My Dirt Bug rides MUCH better now. I dare say that this is the best modification I have made...
