Here is the adapter for the UNI air filter, as well as the choke lever retainer bracket.
Here is the box stock carburetor mounted. I used 3/16" ID fuel line from NAPA to plumb the carb.
At this point, my Dirt Bug was mostly complete. Just lacking the hydraulic brake. I do like the red foam air filter.
The red hose is the DrainZit oil drain hose. I installed this to make oil changes easier and less messy. I have one installed on my Northstar 13,000W generator with a Honda GX620 V-twin.
Note the metal can fuel filter tucked in next to the engine. The black hose goes from the back side of the filter, winds around and ends up connected to the breather nipple on the valve cover. This took me several tries to get positioned where I wanted, and still not stick out obnoxiously.
This shows the routing of the throttle cable, tach wiring, and ignition kill wiring at the front of the engine. I secured it all with P-clips. It is tight, but the bends are gentle enough so as not to bind the throttle cable.
I disconnected the low oil cut out switch, then just wired the kill switch on the handlebar in parallel with the kill switch on the engine.
Seth K. Pyle
