I just bought a circa 1986 Troybilt Pony tiller with a Briggs 5 horse Model # 130212 0512-01, not running, no compression. Lapped the valves, reset to ,oo6 and .010 inches. New rings (gaps around .015", not ideal but better than originally), piston and rod. Lapped the head and block. I still only have 5lbs compression. I also have a slight amount of compression leak through the carb. Rechecked the intake lash, still .005. The engine did not appear to have been opened before I got it so I do not suspect a cam problem, yet I have the pressure through the carb and essentially not compression.
Thanks guys
Thanks guys
