I have a tecumseh power sport 6hp. It was running really good except it was pretty hard to start so i replaced it with a chinese clone carb instead of another one of those primer bulb tecumseh carbs. I put the new carb on and it started up 2nd pull so i was satisfied with the results until i took the motor for a spin. I have never had this exact problem before, but basically what happened is that the motor had good bottom end torque when i first take off, but then before it can get to full speed it completely loses power but the motor doesnt die. Its not like the typical bogging symptom. then when i stop and try to accelerate again, it doesnt have any torque at all and just seems like its idling even though the throttle is clearly opening properly, And sometimes you can barely hear it trying to accelerate but there is a lot of hesitation. i Checked all the gaskets so i know it is not an air leak Whats the deal? is the carb flat out defective?
