So i had a honda clone engine sitting around that i stripped off a previous project. I got bored with the other one, so i thought why not throw it on a mini bike... never had one before. I had come across a mini drag bike once and it caught my attention.
http://i1136.photobucket.com/albums/n498/thtsjon4u/th_0506104618.jpg
this is what i started with. honda gx200 "box stock project". I had repainted it and done some mild mods to it: 18lb valve springs, high intake and exhaust, throttle plate, removed governor, and added a crank case ventilation.
For the basis of the mini bike i went with the "drag bike" from bad dog.. pretty good starter.. didnt feel like trying to find an old mini bike and cutting it all up. heres what it looks like thrown together...
http://i1136.photobucket.com/albums/n498/thtsjon4u/th_0522232831.jpg
naturally i painted it flat black, its suppose to match the car in the future.
http://i1136.photobucket.com/albums/n498/thtsjon4u/th_0525221853.jpg
so far i welded on some wheelie bar brackets to the back. the gas tank is from a "C" oxygen bottle.. drilled and tapped a hole on one side and the opposite side and end i drilled out a 1.5 inch hole ( so far just using a wedge rubber plug). I got some 5lb nitrous bottle bracket holders to hold the tank, which i had to cut and rivet back together to fit right. The back of the tank is held with a bracket that has a 3in rise to it..i just bent it out to fit on the frame.
For the breather/oil catch can i had a mini fire extinguisher laying around that was converted. An old water spicket handle worked well to make the gas tank look like a NOS tank.
...still more to be done in the future.
