OK, so I'm new to the mini bike scene, and at modifying Predator engines. Been reading in here a lot about the importance of either not modifying your engine by removing your governor, or replacing the rod and flywheel if you plan to do so. Just can't find a dedicated thread of instructions.
I plan to use the ARC throttle plate because I had to remove the fuel tank, air filter and muffler to get the engine to fit in my frame. I have purchased the Top plate, Predator mini bike kit, and Billet Flywheel. I just need some instruction for the install.
I found the sticky for the carb clean/jetting install, and the girl at OldMiniBikes sent me a video for the top plate install (Thanks Vicky!), but said I should check here for further help. I'm no mechanic, but I can follow step-by-step directions fairly well :helpsmilie:.
-Is there a sticky or instructions somewhere for the Flywheel removal and install
-do I have to use a fuel pump with the top plate? Does the stock configuration even have a fuel pump - maybe buried in the tank?
-any other good source for written or video how to's?
Thanks for any help, JB
