Hey everyone,
I thought this might make for a good topic. Like a lot of people my favorite modifications are the ones that are free, like removing a governor. Flipping tires around to change traction in different conditions ect.
So here goes... While putting my new Max torque clutch on, the label says to oil every 2 hours with 30 wt oil. Well the small slit your supposed to oil isn't going to allow much oil into the bearing. I decided to make 3 small notches in the clutch to allow oil to be drawn more easily into the bearing. I am also using a more appropriate 90wt gear oil. In the picture you can see I lined up the 3 factory notches to mine. It works perfectly! When you put a drop of oil in the notch and turn the clutch all the oil is drawn in.
So lets hear you tips and tricks!
Jordon
Jordon
