Put a what I believe is a gx160 head on my hemi predator. Running a black mamba sr cam. I tried to use my stock length hemi Pushrod(5.54in) , but I could barely thread the lockout on yhr rocker stud. Replaced the pushrods with 5.34in long, and I can get my lockouts on, but now it seems like I'm not getting full lift from the cam. Lash is set at.003, stamped stock rocker arms, .010 head gasket, piston to valve clearance measured .095. Piston is in the hole .002. Am I using the right length pushrods? Did I miss something on this swap? I wanted to get a set of 1.3 ratio billet rockers, but now I'm not sure with this (what I think) is the wrong length pushrods, and the low clearance from the vales-pistons.
